Originally posted by Rifleman1776
<br />
Originally posted by Mikey
<br />
<br />Item #3: There may be disagreement on this issue. But I, for one, disagree with the finding. A hole is a hole is a hole. Like others, I've drilled a bunch of holes in different woods, if I want a certain size hole I use the drill of that size. If the situation is as you (CS) states, why don't we have one or two, or three, different bits reccomended for each kit? Filling an oversize hole with glue is not craftmanship, it is sloppy and unnecessary, or should be. CS needs to revisit this issue. I, for one, am not happy with this deliberate incorrect reccomendation.
I would have to disagee completely with this statement and go with Eric's. There have been many times where I would be making several of the same type of pen at one time in both acrylic, wood, and resin. I have found that the holes even when drilled with the same bit will be of different sizes when you insert the tubes. In fact, i have found that I need to use thick CS when glueing resin tubes for Sierras, (even after painting the tubes and inside of he blank) but can only use a medium or thin when doing blanks like Cocobolo because the tube has little clearance to start with. This is also true with every other pen that I have made in different combinations.
Also as said before me, you are a penmaker and yu should be the one sizing your drill bit to fit the material. CS can give us all a starting point, and that is normally just fine for the person who makes a few pens for fun, but if you are going to sell them or make a living off of them, you should know enough to do some leg work yourself and make notes of what works well in what material.
I have made a total of 3 1/2 non-wood pens so can't speak to sizes varying with synthetics.
I do sell mine but not to the point of making a living, for whatever that is worth or means.
I drill holes for things other than pens. I choose the drill bit size for the size hole I want without regard to the material. Have never had a problem with over/undersize holes in different materials.
Usually, with CS kits, and those from other manufacturers, the drill bit size reccomended is the correct one.
That they reccomend an oversize bit for just one kit then excuse it off with a "different materials" story is simply not right. It is inconsistent with their normal polcies and emerges as hogwash.
What they are doing is casting doubt on all their reccomendations as well as those of all other pen kit and tool suppliers. As it stands now, with their highly debatable reccomendation, when starting with a new kit, we must now buy a kit, or several, measure the tube then make a drill bit size choice before making pens. A beginner does not know this and gets stuck with oversize holes that need to be glopped up with glue and, perhaps, unsatisfactory results.
I belive that a test would be interesting. Choose a drill bit, almost any size used for pens, and drill into a variety of materials and woods then measure very carefully the ID. I suspect the differences would be so infinitesimal as to be near zero. In fact, CS, as the supplier, should do this before reccomending a bit size if they had such a concern.
BTW, I'm not happy with them about this issue but I still am a fan of the company in general and will continue to do business with them. Including buying kits of the style under discussion.
