I'm on my third set of centers, and about to replace them. The brass tubes seem to carve little rings in the surface after not too long, even with my sad attempt to use blue tape to protect them.
What are some good centers you would recommend?
Have you ever looked at TBCBushings.com? Most of my TBC bushings are from him. Others I managed to get from the manufacturer, or from the place I bought the pen kits from. If you haven't used TBC bushings before, then I think you will find they resolve most of the issue. I have a set of centers that I use with my TBC bushings. I keep them as groove-free as I can, and the TBC bushings dont introduce grooves themselves (they have a 60 degree internal angled surface to properly mate with a 60 degree center). The TBC bushings DO mar the surface of the centers, but that is easy enough to sand out periodically. TBC bushings with a decent (doesn't have to be a great) set of centers gives me very true turning.
My biggest issue with trueness is the quality of my lathe, I think. I'm still fiddling with optimizing my tailstock, headstock, leveling of both, alignment and centering of both. The Wen lathe is not top of the line, but its a good workhorse lathe, and a lot easier to use for pens than my huge Powermatic. But its lack of precision in the ways and such, has certainly given me a non-trivial task of getting everything optimal. I've got things pretty close now, though not perfect, and that has resulted in better turning overall. I still have some issues, haven't quite narrowed down exactly from what yet. It may be that a higher quality live center that doesn't have any wobble at all in the bearing, may be a piece of the puzzle.
Anyway...TBC bushings took me from wobbling and vibrating bushings while turning (which are guaranteed to give me nonconcentric turns), to pretty much dead stable spin on both bushings the vast majority of the time. Sometimes, I think there might be a mating issue between one set of bushings, and one or both of the centers, but its pretty rare.
