BayouPenturner
can you send a picture of the issue. I was able to change my mandrel shaft on the mandrel saverr mandrel.. I used two vice grips and turned the shaft until it was loose enough to remove. I was not able to knock it out. Then I took another shaft fro another mandrel and drove it in and it seems to be fine. The shaft in the mt2 taper is a swedge fit.
