darcisowers
I use VIVA paper towels, starting with 2 coats of thin CA then swap to the delrin bushings, then between 6-8 coats of medium CA, using aerosol accelerant. I sand with a sanding block for the first 2 grits (320 and 400) then go to hand sanding from there out.
only problem I tend to have is sanding thru, but haven't done that in a while.
don't give up.
don't give up.
