Really John? Embedded objects in Alumilite with no air bubbles? I did not think it would work. I guess I need to try it at some point.
Although it takes me about 10 minutes to pour all of the tubes full on one plate of casting. Not sure if there is enough time to do that with alumilite.
Ron I am pretty sure he is using pressure thus the shape of the stand. The time factor is what would concern me the most. I can not work that fast.
Lol, I don't fill the rack with alumilite. I usually keep it around 8 half tubes or 6 less or 4-6 full sized blanks. I pour a lot of Sierra sized alumilite blanks. Also, Embedded like pine cones and pods but definitely under pressure. I don't use alumilite with brass tube casting but I'm planning on using it on my next watch part blanks. The last summary pour melted and distorted the images on my watch faces over the long period of time it took to set.
let us know how the watch part blanks come out using Alumilite. Also when you say it melted the face of the watch, what resin were you using, what mixture did you use and did you put it in a toaster oven to cure?? Also what was the face made of?? Was it a paper dial covering a thin piece of metal or something else?? I have yet to do a watch part pen but will be soon so I am taking notes. thanks.
