cueman
I want to thank everyone for the kind coments.
] . The most time consuming part is sanding the parts flat and gluing them together. The aluminum on this pen is roof flashing, but I have also used shim stock.
I am willing to post a "how I did it" on this design, but I don't know where to post it, any guidence would be greatly appreciated. I still have alot to learn on computers. Thanks again.
I use 15 minute epoxy,and med. and thick CA glue, depending on how much time I need to line everything up while gluing the pieces together. I should have used epoxy on this one because the dots are not lined up with the stripes like I wanted. I probably have about 4-5 hours total into this pen (according to my wife I spend way too much time working on pens) <b>she just does not understand </b>[Can I ask what glue you use? Aluminum to wood joints.
Also, do you know how many hours you have in that blank??? If so, will you tell us???
