JimMc7
Well, I have to admit I was a bit skeptical when I read reports that CA acted a lot differently depending on the temperature and/or humidity. I thought folks must be using a slightly different procedure each time. Geez, was I wrong.
Last night I finally switched to wet sanding CA with MM and got my best CA finish to date. I don't know the humidity but the temperature was ~75* F. I was so pleased I refinished a couple of my old pens this morning and great results, too (again, temp <80*F).
This afternoon -- with the temperature in the mid-80s and 60% RH in my shop -- I've tried to re-finish 2 blanks and I can't bring a shine to the finish at all using the exact same procedure as last night/this morning.
I don't think wood type is the variable either because DI, boxelder burl and quilted maple finished great in the cooler temperatures. DI and Amboyna burl I can't finish at all in the warmer temperature. I actually had a decent glossy finish on the 2nd DI which I wanted to improve and now it looks awful.
I'll wait until cooler temperatures and re-try but, for now, maybe I'll just stick to acrylics when it's hot!
Not really looking for a solution here (unless you have one!) -- just confirming what I previously didn't really believe re how temperature can affect CA finish success.
Edit to add: I'm sure some of you get an excellent CA finish at temperatures >80*F and I'll believe you. Just pointing out my particular procedure doesn't seem to work at temps >80*F. My new procedure is a combination of that suggested by Russ Fairfield with the MM usage suggested by "greenmtnguy" (aka Alton -- not sure I got the name/id right and I apologize if wrong). Now that I think about it....maybe I should adapt a procedure used by someone in Texas or Oklahoma rather than those in Idaho & Vermont!
