37/64" Drill Bit Woes and Question
chaplain1101
Two Harbors, MN
I purchased a "Majestic" fountain pen kit to customize as a wedding gift. The first issue was that the upper tube required a 37/64" bit. I dutifully purchased one. It was too big for my Jacobs chuck. Not coming to the forum for advice, I purchased a 3/4" Jacobs chuck. You guessed it - it would not fit either my lathe or my drill press. Will a reduced shank 37/64" bit work in my Nova Comet II lathe with a standard Jacob's chuck, or are there other recommendations?
So there should be a reduced shank drill bit available. Typically, the reduced shank is 1/2 inch.
Search on Amazon for the following item:
B01BVFO3XM
It is a bit expensive, about 30$ but it should last a lifetime.
It is somewhat terrorizing when you drill a blank with a 37/64" bit. I work my way up to that size using about 6 smaller bits starting with 3/8" and going up in size using every other bit in my case (roughly).
You have to be careful that the 37/64" bit doesn't grab the wood and pull its way through. DAMHIKT.
I guess the deming/reduced shank bit piece was covered, but I'm just posting to repeat important information.
both THIS
and THIS
100%. Make darn sure that your Jacobs Chuck's MT is very securely seated into your tail stock quill.
You might want to practice with some throw away blanks. Just a suggestion.
... and unless you have a drawbar holding the Jaccobs chuck in the tailstock, HOLD IT there any time it's engaged with the blank, and especially while you are retracting it.
Just adding on to what Duncan said. 1) NO GLOVES, you don't wan't them getting caught and pulling you in and 2) hold the chuck underhand, meaning with your palm up so that if it does grab and spin you have control. If you have your hand on top of it and it grabs it twists your wrist down and breaks your grip and you are in no position to react safely.
