jbg230
Just purchased a new Laguna 12/16 lathe. My $89.00 Harbor Freight lathe got me started 10 years ago, but it was time to upgrade! Since my HF lathe is a Morse taper #1, I bought a pair of #2 adapters for my chucks and centers. I guess one question is, should I have figured in the cost of buying all new #2 accessories or are the adapters okay for a non-professional like me (assuming they turn true).
I thought everything was going great, but then I used one of them just to see how it would work.
The issue is removing the darn adapter from the chuck or center. I slid the #2 adapter over a Jacobs chuck #1 Morse taper and inserted it into the tail stock. I used a knockout bar as I usually do to remove the chuck. But how do I get the adapter off the chuck? I finally did, but it's certainly not efficient. Not only that, but I realize I can't use a draw bar now. So that's no good! (and the draw bar diameter is a tad wider than the stem at the end of the adapter, so I can't just tap out that stem) Did I buy the wrong type of adapter? Do I cut the stem off the adapter where it flares and tap out the base so I can use the draw bar? Stop being frugal and start over again with #2 devices?
Thanks for help.
Thanks for help.
