Looking for table saw blade
beck3906
Belton, TX 76513
I've spent a few hours looking for a specific table saw blade and not finding anything like I need/want. Maybe someone here can help
Looking for these specs.
10 inch diameter
5/8 bore
5/32 kerf
Prefer a flat bottom kerf
Thanks for any suggestions
Hey Rick,
I have never heard of a 5/32" kerf table saw blade. This is a full 1/32 wider than a standard full kerf blade.
All of mine are full kerf 1/8". The ones that have a flat bottom cut are the rip blades with either a Flat Top Grind or a Triple Chip Grind. Some of the combination blades will be close to a flat bottom kerf with 1 Alternate Top Bevel teeth and then one Triple Chip Grind.
All of my table saw blades are CMT brand and I got them from Taylor Toolworks (small family owned business). This link takes you right to their 10" Full Kerf blades.
Mortalis beat me to it. Infinity makes a couple of different carbide wide kerf blades, one 5/32" and one a full 1/4", both with flat bottom cuts, but they are only 8" blades. They were designed for making box joints and tenon shoulders. - Dave
Try searching for 4 mm. I found this but it's 12 inches and no idea what the arbor hole is. They have a note to contact them if you can't find the size you're looking for.
I suppose you can have something ordered and special made. But you do not say what you are using it for and why that size? I wish you answer these questions and maybe we can be more of a help. The only thing I thought of was a dado blade and here is one that has what you want but is a 8" blade. You probably can get a single replacement blade as opposed to buying the whole set. Just a suggestion.
https://infinitytools.com/products/...ick-kerf-flat-top-saw-blade-package-5-8-arbor
10 inch diameter
5/8 bore
5/32 kerf
Rick, Woodpeckers has a new series Ultra-Shear flat top grooving 10" x 40 tooth table saw blades in 1/8", 3/16", and 1/4". I bought a 1/8" blade to be used for creating Kumiko project materials. Here's the link to their site.
Gregg
