New pendant jig
hilltopper46
East Troy, Wisconsin, USA.
Several years ago I made a pendant jig from plans posted on the internet by David Mueller. I have made a LOT of pendants over the years with that jig. It has gotten to the point it is no longer running as true as I would like.
I saw the Duxbury jig somewhere on line and I thought I would try that - I made a few pendants with it but there are some things I don't care for.
So last week I was hit by an unexpected surge of creativity and decided to try making one of my own design. I thought I would post it here for comments, etc. If anyone had done this or something similar to it I am not aware of it - I was inspired by both the David Mueller jig and the Duxbury jig.
The two things I wanted in the jig were the ability to re-clock the workpiece without removing the jig from the lathe, and for the offset to be linear. I seem to have succeeded with the jig is pictured here.
The jig is shown with a screw driver engaging the screw that clamps the mount for the workpiece for re-clocking it for grain alignment or decorative purposes. The other side is what I call a lead screw that lets me use a socket driver to offset the workpiece to drill and finish a hole, or to do decorative turning on the workpiece. The workpiece is held to a pedestal with double-sided tape. The mount for the pedestal is dovetailed to hold it into the jig.
This second picture shows the workpiece offset and preparing to drill hole into the pendant.
I have 5 or 6 hours in the making of this jig, which includes some testing time. If I made another I think I could do it in 2 or 3 as some trial and error stuff is behind me.
Making this was so much fun that I am thinking about building another one which would use a different method to hold both the slider and the workpiece in position. I have made 6 or so pendants on this one now and it is working very well.
The last picture is the last pendant I made on it this afternoon. I left it mounted as I intend to take it to our local club meeting this coming Monday.
I love jigs of all kinds. I am working on a couple myself for some projects I have in mind too. You see a problem and you think it through. I bet you got a good feeling when it all worked out. There is no shame in taking a few ideas and tweaking to make something work. That is a nice pendant. Thanks for posting. I guess this thread could have gone in a couple different forums such as the jigs forum too.
Well, it is a requirement to post plans with jigs. EVERYBODY knoooows that, sheesh.
But seriously, I am intrigued. Do you have plans you could share with up for this? I have been wanting to figure something like this out but why reinvent the wheel?
Yay - great jig! I had to read through your post a few times before I understood how it works. It took me a while to see the part to which you tape the pendant blank can rotate inside the part that slides off center when you crank the threaded rod. Nicely done!
I'm sorry - the only plans I have are in my head. I have written up some stuff here.
very neat idea, well executed.
I've made one offs just by offsetting and boring for the pendant but that's far more versatile. Great idea
That is very cool. Did the jig itself allow you to carve the decorative arcs in there also? I'm trying to picture how that would work with them appearing offset rather than concentric.
I bought a Joyner offset jig a few years ago. I've used it a few times but have not pursued its use in quite awhile. Your pendent makes me want to get back into it a little more.
Tony; Very Good ideas.
The World Wide Woodturners is having a gathering in Wisconsin in 2026 called "Level UP". This is not just for pen turners but you might be interested.
Great concept and kudos on production. I like the idea of the variance of spacing as opposed to presets.
