Sierra vs. Gatsby
Wolf Creek Montana
Probably a really dumb question, but here goes.
I've got a bunch of acrylic blanks that I've purchased over the years that call for a Sierra kit. I don't have any Sierra kits but I do have quite a few Gatsby kits.
1. Are they interchangeable?
2. Can the pen clips be taken off a Gatsby? If so, how? The reason I ask is that on some of the blanks there is writing that goes all the way around the blank and the clip has a tendency to block some of the writing.
3. Which is the best way to orient the pen clip on blanks that have certain features on them (like Military logos, sayings etc.) that I don't want to be broken up?
That's it for now, maybe more later. Thanks for any help up front.
I've never personally double checked but if you use the bushing & tube reference sheets from the library it will tell you if things are the same. It's pretty handy.
I've used it a few times to double check somethings.
So I had to take a gatsby apart over the weekend. Yes, you can remove the clip. It's held in place by a brass cylinder that goes around the center of the clip assembly.
