Coffee and Paprika Inlay
Wmcullen
Fairfax, Virginia
I'm not sure if this process is right or wrong; unique or common. But it works for me and I want to share in case it's interesting.​
22: Coffee and Paprika Inlay
Inlay Station
last post: 21- Coffee Ground Spiral
Using a router to dig trenches I've been making pens inlaid with materials like coffee and paprika.​
The Problem
My process involved CA glue and got sloppy. It needed some organization.
Solution
(Not rocket surgery, just how I did it.)
I constructed a "station" along with some simple tools.
Inlay Station
The wood blanks were held on 0.25" bolts. Since I make a few at a time, there is also a drying area.
A few simple tools for pouring and packing powder material streamlined the process.
Coffee "recipe"
I scooped used coffee grounds into a pyrex dish and microwaved for 20-30 seconds.
Poured out liquid, stirred and let dry.
Every few hours after that the dish was microwaved for 20-30 seconds and stirred.
Repeated until grounds were completely dry.
Paprika
Bought a big container at the Dollar Store.
Inlay Process
Working in small sections, I put thin CA into the trench.
Poured coffee or paprika using funnels and tools.
Worked at a deliberate, but not rushed, pace.
Covered with more thin CA glue and packed down.
Repeated until the trench was filled and let dry.
Turned roughly to see how the material looked.
If I saw "caverns" the above steps were repeated.
Masking Tape
For this pen I used both coffee and paprika. Masking tape covered areas not being worked on.
Also, a little masking tape on the "spatula" end of this little tool made it somewhat reusable.
Whereas these little packing tools were basically disposable.
Summary
I appreciate everyone who has written about these versatile and thrifty inlay materials including Curly and robutacion.
It can be a messy process, but with some time the results can be satisfying.
3D Model
I'm attaching the 3D model for anyone who has the ability and interest to print it.
I tried to be efficient with space so that everything prints within a small footprint.
The file is called InlayBox.zip which contains an .obj file
Thanks for looking.
Cullen
  • inlayBox.zip
magpens
Canada
@Wmcullen
I greatly admire your ingenuity !!!! . The results are very cool !!!
I'd be interested, please, in seeing the jig you use to hold your blank while routing .... particularly interested in the angled router cuts.
Wmcullen
Fairfax, Virginia
Thanks for the note and question, Mal.
I used a custom twist jig which works like this:
To make this particular design I raised and lowered the blank onto the router at somewhat random distances.
mark james
IAP Collection, Curator
Medina, Ohio
Great innovations again Cullen. I really like the detail you put into your jigs - a real asset to the IAP membership.
Only question and it is VERY important... Plain Paprika or Smoked Paprika (I typically favor Smoked Paprika). 🤣 🤣
MPVic
Hamilton, ON, Canada
You kill me, Cullen with your outstanding ingenuity and creativeness - those 3D printed "jig works" are so very, very, clever. I so enjoy you sharing your work.
P.S. how's rehab going?
Wmcullen
Fairfax, Virginia
Sorry. I model in Autodesk Maya software which does not have great stl export capabilities. I've done it, but the resulting geometry is either pretty awful or it just fails to export. I went back and tried with this file and got a 0K file (empty). The only hint I have for using the obj files is that when I bring it into my Cura software to make a gcode, I consistently need to scale the obj up by a factor of 10. And then everything works smoothly. I understand this may not be helpful since we all have our own particular software/printer setups.
Valin6210
Webster, NY
Thanks for letting me know. I will try and bring the obj file into Cura to see what happens.
ghostshadow
Indianapolis
I know this is an old thread and I apologize for the necro. I thought I would update it with a-to-scale STL for anyone looking to still print this model. I hope it helps! Really dig the design!
  • inlayBox.stl
Wmcullen
Fairfax, Virginia
Thanks so much for doing this!!
I appreciate you taking the time to convert the file. And I'm glad you like it.
-Cullen
