Noob bushing question
Not exactly sure. But the Gatsby twist kit calls for a 27/64ths drill bit The Gatsby Grande is a 3/8in. drill bit. The Wall street is also a 27/64. Not sure but it would be close. Suppose you could try them on each other and verify with calipers to be exact. Hopefully some one can confirm.
Turnbcrazy43
Turnbcrazy43
I have kits that are 27/64
No harm in trying... Would like to find some stainless steel bushings so I don't have to be "as worried" about turning them down while learning the craft.
There is an IAP bushing app that is amazing and would have the answer for you. It is in the resources section. I've attached a screenshot of the gatsby twist (psi) and the wallstreet II. There are multiple types of these pens so I'd recommend verifying I picked the right styles via the app. Hope this helps
Just found it and installed -- going through it now..... so far they are the same...... fingers crossed....
Its finally cooler down here in FL so being in the garage season has started....
According to the IAP app, they take the same bushings, 0.474 inches. I highly recommend the $0.99 IAP app for iPhone and Android.
I have used Rockler's Gatsby and Manhattan pen kits, which use the same bushing sizes, and I have interchanged them. I assume the WallStreet II is the same, based on the IAP app and many other posts here.
I was sloppy with tubes between Manhattan and Gatsby kits, and didn't worry about which tubes matched which kits. They measured the same, but when I went to assemble them, one pen was a loose fit. The difference was so small that I doubt I could have measured it, but the loose fitting one could be pressed in by hand. It is at my desk, held together well enough for me to use. A drop of CA glue would eliminate any concerns easily. The internal diameter difference must have been around 1/1000 inch or so.
installed
Try to avoid using CA anywhere near your plated components. When if "off-gases", it can leave a white residue on your parts.
Better to use Blue or Red Loctite--apply it IN the TUBE, so it does not get directly onto the parts. IF it does, wipe off while still wet.
I have started using this procedure often, even if the tubes fit the components very well--no harm in a little "long-term grip" added.
FWIW,
Ed
