BeeAMaker
SUCCESS!
Thanks to everyones advice and tips I think I got it. I didn't sand or polish that blank yet, I used my round carbide as a skew chisel then went over it with some #0000 steel whole, very smooth and way less chipping. (I think temp might have something to do with it also, see below)
I want to give a big shout out to Ed from Exotic Blanks for taking the time to look at my technique. I will be taking what I learned to the next maker meetings in the upcoming weeks. With my new found confidence, I believe I can save at least 2 of the 3 blanks.
Now to change the subject, but I think it is related as I believe this has something to do with Temperature.
I noticed the brass tube is proud of the blank, but only on one end. This is true with all my plastic blanks I have glued up and squared. I square them on a disk sander so the ends should be flush. Here are a couple pics.
And like I said, this is only on one end, so I am thinking maybe I don't have enough adhesive at this end, allowing the brass to expand - or the plastic to shrink beyond each other. Thoughts? These are all "esters" material as well I had one allumilite one that had been turned and one wood blank that i had turned that were OK. I think it is a temp issue, but if they are glued properly, (and the glue holds) they should expand and contract together.
Thoughts?
Thoughts?
