shaving brush help?
See more from r-ice
r-ice
markham
Okay so I've had all this stuff at home and have been busy turning pens and finally today took the plunge and started it. I was wondering the side with the hole closest to the headstock, how do you face it? I don't have a mill that would mill the end to correct the slant.
here is the photo
http://imgur.com/FYT7S
ed4copies
Local Chapter Manager
Racine, WI, USA.
IF you have a scroll chuck, you chuck the blank from the closed end and face the hole end.
IF you don't have a scroll chuck, you can make a "Jam chuck" by turning a dowel between centers. One end matches the morse 2 taper in your headstock, the other end has a sloping tenon that holds the drilled blank in place. Bring up the tailstock for support of your blank and use a parting tool to face your blank (the hole side, now in the jam chuck).
PenMan1
Eatonton, Georgia
The best way I have found to do brushes is on a bottle stopper mandrel. This gives you room to face the opening where the badger knot is inserted. It also makes it easy to finish the other end without any re-chucking.
PenMan1
Eatonton, Georgia
If you have a collet chuck, a regular old 3/8 bolt threaded into the blank works great, too! Simply slide the bolt toward the tailstock for room to face the hole.
ed4copies
Racine, WI, USA.
This WILL WORK!!! Cut gently with a sharp tool, you have little room for error.
PenMan1
Eatonton, Georgia
I use six inch bolt and a jam nut. So can have over three inches of room. Us old guys with bad eyes need a "wide birth" :)
ed4copies
Racine, WI, USA.
You are probably too good a turner to have experienced this, Andy. When you have 3/8" bolt supporting your turning, a bit too much pressure into the wood and it will send the blank off center, which makes it HIT your tool HARD, and "not good" thiings happen.
el_d
Lockhart, Tx, USA.
I use a paddle bit to square the ends and place the center hole for the 3/8inch tap to fit.
An oversized Forstner will work also.
OKLAHOMAN
Costa Rica
I do it just like Andy, useing a bottle stopper mandrel. Drill a 11/32 hole and tap 3/8 on acrylics and on wood just screw it on.
fernhills
Hellertown, PA, USA.
I just back the BS mandrel out of the collet a little and get it square. Or i what i do most of the time is turn the blank between centers till round and square on a disc sander. Doing it the disc sander way insures my drill and tap meets a flat face.
