locating a m4.2 x .35 tap
I'm trying to locate a M4.2 x .35 tap that doesn't cost $33, Found one at Richard Greenwald but to pricey.
Penultimate
Bartlett, IL 60103
Greetings
4.2mm is really close to a #8 tap diameter and .35mm pitch is really close to 72tpi. Victor machinery has #8-72 for $11.50. If the part that uses this tap is plastic then the threads are likely molded and the #8 tap may work. I have been successful locating non metric taps for molded threads because they are a "sloppier" than cut threads. Good luck.
