I need a self stick loop or hook sheet
mmayo
Tehachapi, CA
Currently I use PSA sandpaper on a jig to sand my newly glued blanks flush. I use Rick Herrell's jig in a drill chuck to hold the blank. I would like to attach a sheet of hook material to the flat round piece spinning at the headstock and use the loop sandpaper instead of PSA.
My question, where can you buy a sheet (6+") of the hook material?
Thanks in advance for your time.
eharri446
Marietta, GA
Amazon also has them in a 2 inch size I think they were $8 for a pack off ten. They have a top and bottom section one of which is the loop and the other is the hook. Both are PSA backed.
