2018 Kitless Pen Tap and Die Group Buy
Select the items you would like to order
  • M14X.8 Triple Start Bottoming Tap
    Votes: 5 11.4%
  • M14X.8 Triple Start Plug Tap
    Votes: 9 20.5%
  • M14X.8 Die
    Votes: 10 22.7%
  • M13X.8 Triple Start Bottoming Tap
    Votes: 13 29.5%
  • M13X.8 Triple Start Plug Tap
    Votes: 20 45.5%
  • M13X.8 Die
    Votes: 23 52.3%
  • M12X.8 Triple Start Bottoming Tap
    Votes: 6 13.6%
  • M12X.8 Triple Start Plug Tap
    Votes: 19 43.2%
  • M12X.8 Die
    Votes: 19 43.2%
  • M11X.8 Triple Start Bottoming Tap
    Votes: 2 4.5%
  • M11X.8 Triple Start Plug Tap
    Votes: 6 13.6%
  • M11X.8 Die
    Votes: 7 15.9%
  • M6.4x0.6 Plug Tap (Bock #5)
    Votes: 13 29.5%
  • M6.4x0.6 Bottoming Tap (Bock #5)
    Votes: 5 11.4%
  • M7.9x0.6 Plug Tap (Bock#6)
    Votes: 11 25.0%
  • M7.9x0.6 Bottoming Tap (Bock#6)
    Votes: 6 13.6%
  • M6.5x0.5 Plug Tap (Jowo#5)
    Votes: 8 18.2%
  • M6.5x0.5 Bottoming Tap (Jowo#5)
    Votes: 4 9.1%
  • M7.5x0.5 Plug Tap (Jowo#6)
    Votes: 14 31.8%
  • M7.5x0.5 Bottoming Tap (Jowo#6)
    Votes: 8 18.2%
  • M8.5X1 Plug Tap (Bock Section)
    Votes: 9 20.5%
  • M8.5X1 Die (Bock Section)
    Votes: 8 18.2%
  • Total voters
    44
  • Poll closed .
eharri446
Marietta, GA
Here is the price quote from TapCo:
M14-.8 Btm** 1pc* 178.64,* 2pc* 137.61,* 3pc* 104.39,* 6pc* 80.41ea,* 9pc* 69.19ea,* 12pc* 5808ea,* 24pc* 51.81ea
M14-.8 HS 1"OD Die* 1pc* 184.80,* 2pc* 138.60ea,* 3pc* 103.60ea,* 6pc* 78.40ea,* 12pc* 70.00
M13-.8 Btm 1pc* 162.40,* 2pc* 125.10ea,* 3pc* 94.90ea,* 6pc* 73.10ea,* 9pc* 62.90ea,* 12pc* 52.80ea,* 24pc* 47.10ea
M13-.8 HS 1"OD Die**** 1pc* 184.80,* 2pc* 138.60ea,* 3pc* 103.60ea,* 6pc* 78.40ea,* 12pc* 70.00
M12-.8 Btm* 1pc* 159.00,* 2pc* 121.90ea,* 3pc* 91.50ea,* 6pc* 68.40ea,* 9pc* 563.00ea,* 12pc* 48.40ea,* 24pc* 43.20ea
M12-.8 HS 1"OD Die** 1pc* **184.80,* 2pc* 138.60ea,* 3pc* 103.60ea,* 6pc* 78.40ea,* 12pc* 70.00
M11-.8 Btm*** *1pc* 158.00* 2pc* 119.80ea,* 3pc* 89.50ea,* 6pc* 63.45ea,* 9pc* 53.45ea,* 12pc* 44.10ea,* 24pc* 37.70ea
M11-.8 HS 1"OD DIe** 1pc* 184.80,* 2pc* 138.60ea,* 3pc* 103.60ea,* 6pc* 78.40ea,* 12pc* 70.00
SIngle lead taps
M6.4-.6 plug 1pc* 125.00,* 2pc* 90.20ea,* 3pc* 61.90ea,* 6pc* 40.15ea,* 9pc* 26.15ea,* 12pc* 22.45 ea,* 24pc* 18.40ea
M7.9-.6 *plug* 1pc 126.10,* 2pc* 91.60ea,* 3pc* 62.90ea,* 6pc* 41.50ea,* 9pc 31.60ea,* 12pc* 23.50ea,* 24pc* 18.50ea
M6.5-.5 Plug *1pc* 125.00,* 2pc* 90.20ea,* 3pc* 61.90ea,* 6pc* 40.15ea,* 9pc* 26.15ea,* 12pc* 22.45 ea,* 24pc* 18.40ea
M7.5-.5 Plug* 1pc 126.10,* 2pc* 91.60ea,* 3pc* 62.90ea,* 6pc* 41.50ea,* 9pc 31.60ea,* 12pc* 23.50ea,* 24pc* 18.50ea
M8.5-1 Plug 1pc* 130.35,* 2pc* 94.1ea,* 3pc* 66.99ea,* 6pc* 44.66ea,* 9pc* 34.35ea,* 12pc* 25.65ea,* 24pc* 20.80ea
M8.5-1 HS 1"OID DIe* 1pc* 131.60*** ,2pc* 99.40ea,* 3pc* 74.20ea,* 6pc* 56.00ea,* 12pc* 50.40ea
Based on the numbers that I have from the survey, Here is what each item costs:
Item Qty Price
M14X.8 Triple Start 14 $58.08
M13X.8 Triple Start 33 $47.10
M12X.8 Triple Start 25 $43.20
M11X.8 Triple Start 8 $63.45
M6.4x0.6 (Bock #5) 18 $22.45
M7.9x0.6 (Bock#6) 17 $23.50
M6.5x0.5 (Jowo#5) 12 $22.45
M7.5x0.5 (Jowo#6) 22 $23.50
M8.5X1 (Bock Section) 9 $34.35
NOTE: All taps count towards the price for that size tap. So we had a total of 14 for the M14X.8 Triple Start between the plug and the bottoming and that determined our price.
Item Qty Price
M14X.8 Die 10 $78.40
M13X.8 Die 23 $70.00
M12X.8 Die 19 $70.00
M11X.8 Die 7 $103.60
M8.5X1 Die (Bock Section) 8 $74.20
Based on the prices above, I will need a go/no go decision from everyone who is interested to see if we go forward.
Once I have everyone's response by to go or not, I will do all of the other paperwork to get us started, or have the thread closed by the mediator.
eharri446
Marietta, GA
I am wondering about the diameter of the JOWO #6 Bottoming Tap.
Although the difference is only very small, and it may make no difference in practice,
other sources I have specify it as:
M7.4x0.5 Bottoming Tap (Jowo#6)
__________________
Mal
Mal, I noticed that too. If anyone can shed any additional light on the actual size, I would appreciate it.
duncsuss
Wilmington, MA
I can't speak from authority, but I can say that some JoWo #6 housings are very tight when I screw them into sections made with my M7.4 x .5 tap. To the point where I'm thinking about getting one of the M7.5 x .5 taps to get that little bit extra slack in there.
I believe the 0.1mm diameter difference gets divided in two, resulting in 10% less active thread each side (0.1mm / 2 = 0.05mm, 0.05 / 0.5 = 10%). I can live with that if it means I can get the housing out of the section without mangling parts.
magpens
Canada
Based on Duncan's experience I want to add a M7.5x0.5 Plug Tap (Jowo#6)
With this addition I am in for FIVE taps :
M6.4x0.6 Bottoming Tap (Bock #5) ***** - WANT BOCK #5 Bottoming Tap
M7.9x0.6 Bottoming Tap (Bock#6) ***** - WANT BOCK #6 Bottoming Tap
M6.5x0.5 Bottoming Tap (Jowo#5) ***** - WANT JOWO #5 Bottoming Tap
M7.5x0.5 Bottoming Tap (Jowo#6) ***** - WANT JOWO #6 Bottoming Tap
M7.5x0.5 Plug Tap (Jowo#6) ***** - WANT JOWO #6 Plug Tap *** ADDITION ***
conandy
Denver, CO
I am in for the following, which I believe matches my survey responses:
M13x.8 triple plug tap $47.10
M13x.8 triple bottoming tap $47.10
M13x.8 triple die $70
M7.5 x 0.5 plug tap $23.50
M7.5 x 0.5 bottoming tap $23.50
Thank you.
RangeRat
Arkansas
I'm still in for my original request:
M12x.8 triple start plug tap
M12x.8 triple start die
M6.4x.6 plug tap (Bock #5)
M8.5x1 plug tap (Bock section)
Thanks for the opportunity to participate in this!
Pennsylvania
__________________
Mal
Same question from me
eharri446
Marietta, GA
I get two different answers. Another member pointed out that the JOWO #6 feeds were really tight with the M7.4X.5 and that he thought the M7.5X.5 might make it easier to remove the feed with out destroying it.
Sorry, however in the last group buy we bought the M7.5X.5.
eharri446
Marietta, GA
Something else that sometimes confuses people is the drill bit size to the Bock #5. The tap is a M6.4X.6 which means that you would use a M5.8 drill bit. In fact the end of the Bock#5 feed is 5.9 mm in diameter and it would not fit in the 5.8 mm hole so we have been advised to use a M5.9 drill bit.
mrburls
San Antonio Tx.
Here is my list I would like. One of each.
Bock #5 M6.4 x 0.6 bottoming tap.
Bock #6 M7.9 x 0.6 bottoming tap.
Bock #6 M7.9 X 0.6 Plug tap.
Bock M8.5 X 1 tap section.
Bock M8.5 X 1 die section.
M14 x .8 triple start bottoming tap.
M12 X .8 triple start bottoming tap.
Keith
PFMan
Barcelona
I am in for a 13mm triple start tap and die at the above prices. Please contact if prices change.
Sent from my ONEPLUS A3003 using Tapatalk
Albion, MI, 49224
-------------------------$89.80
Who, how & when is the money needed
duncsuss
Wilmington, MA
If the current price breaks remain valid, I confirm my initial selection of:
M14 x .8 x 3 plug tap
M14 x .8 x 3 die
M12 x .8 x 3 plug tap
M12 x .8 x 3 die
And add:
M7.5 x 0.5 bottoming tap for JoWo #6
Thanks for taking on this challenge once again :)
nicolanti
Sandusky, OH
Also interested
Please let me know when you start accepting orders. I am interested in a number of these items.
Thank you,
David
mballen34
NE Ohio
I confirm my interest in :
M13 x 0.8 Triple Start Plug Tap
M13 x 0.8 Die
M7.5 x 0.5 Plug Tap (Jowo #6)
Much appreciation for putting this together!
Matthew
