Pen finals, clips and accent rings
Amihai
Israel
Hello,
So far, I've been making relatively simple kitless pens, as you can see in the first photo attached. The entire barrel and cap being made from a single material (usually wood in my case), without any hardware such as accent rings or clips. This simple design has its artistic advantages, but as I'm always interested in improving my skills and trying new things, I wanted to try adding a clip and some different color "finals" (I think this is how you call them?) So, for example, the cap is made from wood in the middle and Ebonite or Acrylic beginning and end, with a clip fitted between the Synthetic end and the wood (second photo, NOT MY PEN!).
The problem is that I don't have a clue how to make such a thing and where to begin.
So, kitless pen makers: may I ask you how do you make those complicated pens?
Hopefully you will save me some trial and error. Thank you for any help!
hooked
Boston
I use several methods to do this now, and I will go through the method that I use with manufactured clips. I am not saying that my method is right, but it works for me. I have had no formal training on doing any of this and figured it out by trial and error and asking lots of questions to people with more metalworking experience on IAP.
Primarily for a blind cap or cap finial, I drill out and thread the same as my section, M10 x1. I prefer to thread all of these pieces and try not to use glue except to secure my metal piece to the finial. I turn down the finial until very close to the right dimension in a section mandrel, and then turn it down to final size and shape while inserted into the pen...very carefully. Make sure to drill out your tenon because if you have tight tolerance, your nib will need the extra room to prevent the tip from hitting your finial. If going with a clip, I start with a premade clip from Beaufort Ink with an outside ring diameter of 12mm and inside of 10mm. I use a 12mm endmill and create a channel into the top of the cap for the clip to sit in. I use a mini file that I have trimmed down to be the width of the clip and file a little channel for the clip to come out. My finial threads are 10mm, and the inner diameter of the clip fits perfectly on my tenon.
To make trim rings, I use a pepetools disc cutter to make washers to fit out of aluminum, brass, copper, nickel silver 18g flat stock. I turn them down with the finial. Others use a jeweler's saw and cut them out of sheet stock. If working with sterling, I now use sterling wire and solder my rings to fit. The disc cutter works well with silver, and I have found that I can use the cutouts for finial coins, but there is still a lot of waste, and silver is quite expensive.
Overall cap finial. M10x1 threads. Nickel silver washer cut out and finial coin installed. Make sure you drill out your tenon to allow the nib to fit.
End milled out the channel to hide the clip ring. Notice how the nib extends past the opening.
Filed out an opening on the right so that when threaded, the ring sits flush.
Threading on the finial and fitting the clip to fit in the channel and exiting through the slot.
Fully threaded.
Blind cap on the barrel partly threaded to show.
Amihai
Israel
Fully threaded.
Thank you very much!
TDahl
Brentwood
I think this is one of the most complicated topics frequently discussed in the pen makers' world. Your question also covers two separate areas of pen making: Finials and metal work (clips and rings). The finials just another extension of pen making with the most complicated part being the cutting of tenons. I trust most pen makers will be able to figure that part out, so I won't go into that subject here. The metal work is where it gets complicated. In my opinion, a quality made pen can look cheap when matched with poorly made clips and rings. The metalwork is an art in itself.
I would suggest researching and learning the arts of Metalsmithing (and/or Silversmithing) and jewelry making. The most basic skills you will need to learn are cutting with a jeweler's saw, using a torch to anneal and solder metal pieces, shaping metal pieces with files, and polishing. There are also a number of pieces of equipment you will need to get started. Rather than list everything here would recommend the following books:
1) Metalsmithing by Jinks McGrath - https://www.amazon.com/Metalsmithing-Jewelry-Makers-Contemporary-Inspirational/dp/0764165844
2) Silversmithing by Elizabeth Bone - https://www.amazon.com/s?k=Silversm...g+elizabeth+bon,stripbooks,335&ref=nb_sb_noss
3) Simple Soldering by Kate Ferrant Richbourg - https://www.amazon.com/s?k=simple+s...ple+Solder,aps,379&ref=nb_sb_ss_ts-doa-p_2_13
Kate Richbourg also has a Youtube channel that covers some of the tutorials in her book.
Once you are confident in these basic skills, I would recommend referring to a couple IAP tutorials:
1) https://www.penturners.org/resources/how-to-build-my-clips.398/
2) https://www.penturners.org/threads/clips.171776/#post-2135746 – (This was a post from Jalbert - scroll to the top of the page.)
Be prepared to spend time and materials during that you will probably throw out during the learning process. This is a learning-by-error venture. I have been studying metalsmithing on my own over the last two years, and only have been making metal clips over the last six months. There are other makers on this platform who are much more experienced and knowledgeable than me who have years of jewelry making training and experience and their work reflects it.
I don't want this to discourage you from advancing your skills, but I believe you should be prepared for what you are getting into so you don't become discouraged along the way. Once you become proficient with working with metal components, the creative possibilities are endless.
Good luck.
TDahl
Brentwood
Fully threaded.
I will echo Mark's comments on using the Pepetools disc cutter. It allows you to cut better ring and cabochon blanks.
Amihai
Israel
2) Silversmithing by Elizabeth Bone - https://www.amazon.com/s?k=Silversmithing+Elizabeth+Bone&i=stripbooks&crid=2SM60BUSTVFJY&sprefix=silversmithing+elizabeth+bon,stripbooks,335&ref=nb_sb_noss
3) Simple Soldering by Kate Ferrant Richbourg - https://www.amazon.com/s?k=simple+soldering+a+beginner's+guide+to+jewelry+making,+book&crid=2SOW6K1NDXOSX&sprefix=SImple+Solder,aps,379&ref=nb_sb_ss_ts-doa-p_2_13
Good luck.
Thank you, but actually I didn't mean to make my own clips, I intended to purchase ready made ones. I was mainly curious on how to attach those clips to the pen itself.
darrin1200
Lyn, Ontario, Canada
As for attaching a clip, Marks method above is pretty well the standard. His finial is rather ornate, but a simple one works and looks dust as good.
