Casting Playing Cards
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
Here's a thread on the topic from a few years ago
JohnU
Ottawa, Illinois
Like mentioned in the older post linked above, you have to delaminate them. Most playing cards are made in 3 layers… front, back, and middle ( which gives them their rigidity. Avoid paper or pvc cards. They won't work well with resin. I recently made a video demo which includes how I make and cast playing cards, for the upcoming Nov 5-6 virtual MPG + Small Turnings event. If you're going to view those demos, it will definitely give you some direction.
PENfinity
Virginia Beach
I use the travel deck size for my card pens.
I gently sand the cards with 220 grit paper to thin them down to make them flexible enough to wrap around the tube.
I then glue to the tube with CA
Hope this makes sense,
Mike
Very much so! I like that concept! So the sanding doesn't damage the cards? And do you seal them with anything to protect it from the resin?
PENfinity
Virginia Beach
Thank you for your response
PENfinity
Virginia Beach
Thank you very much John! Yes I have been delaminating them but my issue has been the resin seeping thru the paper. I'm using Alumilite resin. I need to know how to prevent the resin from destroying the card after I delaminate. I did register to attend the upcoming MPG event and I'm so excited! I will most definitely check out your links.
PENfinity
Virginia Beach
PENfinity
Virginia Beach
Thank you
Fayetteville, North Carolina
Check out Leaping Lemur Craftworks to get an idea for the casting of cards. They do a lot of that and may be willing to offer some pointers if you reach out them. The owner is a friendly guy I have met a couple of times at shows.
wwwgregn21
seattle
John, is your video demo posted somewhere?
JohnU
Ottawa, Illinois
No, sorry. it was only available for the event and the 30 days after.
Stick to using vinyl cards and not paper. Paper cards will show the discoloration from resin soaking in. The vinyl with not.
