Skye
Ok, I had a piece of softer wood, drilled the hole, inserted the threaded mandrel that came with the stopper kits. Turned it to shape, but towards the end it started spinning in place. Apparently the drilled hole is almost the same size as the mandrel, so it stripped the hole in the wood out. Ruined the stopper.
My question is how do I avoid this? Make my own mandrel out of something with a smaller diameter?
