Hello, all!
While polishing acrylic blanks that I am beginning to make, the water used on the polishing material wicks under the end of the blank. My mold is PVC pipe, which requires a light tap with a mallet to remove the blank. I turn with a skew chisel, dry sand up to 600g, then micromesh the full range wet. Do you have any advice on how to keep water from wicking between the brass tube and and acrylic and ruining the blank? Thanks heaps!!
