scrollsawwoodart
This site is truly turning into my new google i'm on here so much:biggrin:
I have been using PVC pipe to vertical cast now for about 6-8 months. Love it, blanks are already round, which seems like i save a lot of resin.
Just a couple questions about vertical casting.
1. What size of PVC do you all use when casting? This would be both diameter as well as length. I know we all try and conserve resin especially on a tight budget. What length is the standard for most pens. I think I recall cutting mine to about 5 1/2 inches.
2. I just got the PSI collet system so I could hold the round blanks. Anyone know a good size PVC that will allow the blank to sit right into the collet or are you going to have to always trim them down first?
3. Can you vert cast alumilite? I am going to buy the 32 oz to play with and see how I like it. I have been only using Silmar 41 since I first started casting. I have made a special stand for my pressure pot that holds the PVC so I have pressure.
Thanks for helping answer my questions. Now back to the search feature of this great website.
Jesse
Jesse
