Russianwolf
So yesterday I was driving to work and it'd been raining. I hit the brakes a bit hard due to an idiot and the ABS kicked in but the both the ABS and Brake lights stayed on after I started moving again and the peddle now seems pretty soft.
I checked the fluid this morning and it seemed low so I refilled, but again the peddle is soft. The brakes are still working, but engage much lower than I'm used to. I'm thinking that the rubber piston on the master cylinder may be the culprit.
This is on the 2000 Dodge Dakota by the way.
Any other ideas?
Any other ideas?
