Sometimes we encounter a question or discussion about what kit is "best" for beginning pen-turners to start with.
Often the suggestion is a "slimline" pen kit, but I am not convinced that is the best choice, even though it's probably the cheapest.
"Cheapest" can often lead you down a road which ends up being more complex or more difficult, in one way or another.
So, after carefully considering this matter for some time, I have decided to "stick my neck out" and state my recommendation for "best".
"Best", like "cheapest", is often a term which compromises other considerations, so I do not claim to have the "absolute best" recommendation.
My choice is the 30 Caliber Express Bullet pen kit from Woodturningz.com. . . You can find it here :-
This is a "classically simple" straight-sided single-barrel design with a lot of visual and tactile appeal for just about everybody, IMHO.
On top of that, the barrel turning could be "advanced" from "straight-sided" to a possibly more appealing "slightly bulbous", as skill level permits.
The barrel utilizes a very common 3/8" diameter brass tube (pen-maker's sizing) which is quite a bit easier to handle than the slimline 7mm sizing.
Plus, the refill is a Parker style, which most people prefer ... most people meaning both makers and users of pens, in my experience.
Besides the "straight-sided" barrel design, and Parker refill consideration, here are other reasons for my recommending this pen kit to beginners :
- a twist action refill extension/retraction mechanism which is generally easy to handle at the beginning of pen-making
- an easy matter of pressing the finished "tube+barrel" onto the finial hardware piece - after unscrewing the actual finial and removal of clip
( the avoidance of complications of pressing combined clip + finial is advantageous in the beginning)
- simple reassembly of the clip + actual finial piece after that pressing operation with a conventional pen press
- simple and tactile pressing of the upper and lower portions of the pen together BY HAND after the above operations
- the obvious appeal (to a guy, at least) of the bullet-shaped lower barrel
These factors are highly convincing for this choice for "starting out" pen-makers ..... in my opinion, or course !!
Minor reservations of this recommendation include the double-twist refill mechanism. . Single-twist would be preferrable, and could be arranged at further expense.
Also, the pen kit is fairly low-priced at $8.00 or so, but not as cheap as the usual slimline kit. . However, cost is not everything ! .... Right ?
The simple press-together without the encumbering presence of the clip is quite a big deal .... also "in my opinion", having gone through dealing with the clip on slims.
What say you, everybody ? ... @WoodTurningz
.30 Cal Express Pen Kit - WoodTurningz
The .30 Cal Express is a bold look and is a WoodTurningz exclusive bullet pen!<br /><br /> <span style=font-family: Verdana, Geneva, Tahoma, sans-serif; font-size: 12px; color:#FF0000;><strong>ATTENTION Lefties! </strong>This kit comes with a 2-way mechanism!</span><br />
www.woodturningz.com
