What remarks???? Guess I'll just go buy SAE and work with those.
Geeze, give us a chance to reply before giving up! Some of us have other things to do other than monitor this forum 24/7... well, I don't but I'm sure some do! :biggrin:
You didn't say how you were going to use them but I'm guessing you want to make some home made pens right?
Here is my experience with buying taps and dies this past year, see if it fits your situation, keeping in mind that 80% of my pen making time is now spent working on pens that have nothing to do with purchased kits anymore.
I bought one of the larger Harbor Freight sets, the one that has several of "fine" metric sizes and have only used a couple taps out of that set, now it sits under my workbench collecting dust. Other than a 1/2-20 tap used for making some bodies for the Sharpie refill that is out now, I haven't used any SAE taps or dies to date.
I found that most of the threads I would be cutting were small, fine threads which meant metric sizes so I visited Victor tap and die and ordered every metric tap and die they have from 6mm to 10mm. Sounds like a lot but in my pen making I have used most of them already so I don't see it as a waste especially since I spent $40 on the Harbor Freight set that I will rarely use.
Lastly, even equipped with a full range of metric taps and dies I find that some of the threading I need to do is to match certain feeds and sections so wound up ordering special taps for those. There is no "Set" of taps and dies that will meet every need you encounter so in hindsight I would recommend bypassing any set and focus on the metric sizes mentioned above and whatever specialized taps you need.
Just my opinion!
