Dale Allen
Hello all and thanks in advance for letting me throw out some info and get some input from the group.
I bought a basic kit about a week ago and got the chance to try my hand this past Wednesday. I'm using the basic PR with some blue dye and white and gold powder.
One mold is made from an old poly cutting board. I made 4 sides and a bottom and used CA thick to glue it up. I also used the same thick CA to run a bead on the inside seems. This was also sprayed with activator.
Two other molds are made from 3/4" PVC pipe with the side cut off and the ends plugged.
Admittedly I may have been doing too many things at once for a beginner.
One of the PVC tube molds has a tube with labels that I wanted to do a clear cast with. That one set up fine in about 8 hours and was real hard after 24 hours. The other PVC mold had blue dye with white pearlisent powder. It also set up fine.
Now, the one in the square mold was the consistency of thick pancake mix after 24 hours. In that one I put...don't laugh...some shavings from a black stabilized blank, blue dye and some brass shavings. I wanted to just see what that would look like turned. Anyway, it did not set up.
Room temp was about 65F, low humidity. I did not preheat anything.
On the 2 that set up I used some paper dixie cups that held up fine.
The one that did not set was mixed in a plastic tumbler that held up while poring but later melted the bottom. That was also the one I used to measure with water to find out how much stuff I needed.
Could some leftover water on the bottom rim of the tumbler have caused the problem? I wiped them out but may not have got into the corners of the bottom rim. Could the shavings or brass have caused it to not set?
I used about 8 drops of dye and the cup had about 1.5 oz of PR in it with about 5 or 6 drops of hardener.
I checked the date on the PR but I really cannot blame that because the others set up. Same with the hardener.
I have one of those oil filled heaters in the shop right now and it is sitting on a piece of wood on top of the heater. That's should keep it well into the 80s. It's been there for about 2 hours now and I'll keep checking to see if it begins to harden.
Any ideas as to why that one may not have set?
Again, thanks all for your time and input. This casting process has more of a learning curve than I anticipated but it does show some promise!
