schellfarms
I'm having a problem with my lathe not turning true. The mandrel at the tailstock end is way off--you can see that it's not turning true. I just replaced the spindle and both sets of bearings and tried 2 different mandrels--same result. It makes it difficult to get pens turned to the bushings evenly. I took the rod out of the mandrel and rolled it along the (hopefully) flat surface of my table saw and it rolled in a nice straight line. Is the next place to look the headstock?? If that has to be replaced, is it more cost effective to just replace the lathe and keep my current one for a parts donor? I looked at the Jet website, and can't even get it to pull up the headstock as a part. Is replacing it even an option?
