First thoughts as an easy check is to assure that the ends are indeed square with the center line of the tube.
dial calipers are needed here and a dial indicator is good to have.
Mount and turn a blank to round -- about 5/8 to 3/4 inch tube.  Take it off
The outside turned cylinder is concentric with the tube and should be at 90 degrees to the ends all the way around.  Canting of the ends with tend to skew the mount and lead to an eccentric turning that should show up now.  Use the dial calipers to measure the thickness around the blank.  If you are getting OOR, it shoud be showing up now if it is mounting or gear related.
The dial indicator (mine has a magnetic base) allows me to set the banjo and hook the dial indicator to it and check the variation as the tooling is rotated by hand.  Headstock through to tail stock.  I check at about 1/8th points on the locations checked.  start at the headstock and move to the tail stock checking each piece of the gear (headstock bushings tube, other bushing, live center.  Write the numbers down.
If these check out, the answer is likely your technique/tools.  dull tools and pushing tools into the turning will cause the OOR also.
let us know what you find.
