Ooopps... worded that incorrectly.. should read: "Need help figuring out how to cast a seeded pen blank without a custom made mold...
Aussie Chris
Australia
New to pen making.. want to cast a pen with seeds glued to the tube, but don't have a custom made mold.
Any ideas on how to do this?
cheers
Chris
Plug the ends of the brass tube, then mount the assembly inside a (plastic) tube leaving top end open to receive the casting resin.
The outer tube can really be just about anything. . A drugstore prescription bottle of appropriate size can be used and is good because it already has a bottom. . When the casting has cured, you saw off the bottom, remove the plugs in the brass inner tube, turn off the outer tube.
You really need to give more details about the desired size of your blank if you want to get more specific suggestions. . Also the resin.
Also, have you considered that the seeds might eventually deteriorate ... wrinkle and rot ?
