jholbrook81
I want to move to more challenging turning. I found some pictures on here of pens with stripes of metal running the length of the barrel. I found this was aluminum flashing so I promptly went out and bought some, cut it, scuffed up the faces, and bonded it into two sandwich blanks using System Three epoxy with the 15 min hardener. I clamped the blanks and waited a full 24 hours.
The first blank I tried running the aluminum perpendicular to the barrel to make rings around the pen. When I drilled it it separated at every metal joint.
The lengthwise blank also separated when drilling. I sanded the surfaces that separated, re-applied epoxy, clamped it and let it sit for about 8 hours. I was able to mount the brass tube and start turning. It separated almost immediately with my roughing gouge. I tried my skew on another piece and that worked well. I got it shaped down from rough to round like that. Then I had to put a tenon on the blank so I used my parting tool, and it separated again.
Why is this coming apart on me at every step of the way? I noticed the flashing has a gold color on one side, is that adhesive or something causing my joints to fail?
Any advice you have in this area is welcome. I'm using high speed steel tools, I hone them with diamond stones before each pen and during turning if needed. I do my boring on the lathe with jaws to hold the blank. I do not use bit lubricant. I'm using my 7mm bit cause it's the smallest for now. I'm using bloodwood, sapele, and wenge in my blanks. If there are any questions about tools I'm using or my process please ask; I tried to be very thorough in my description.
