Myrddin
I'm pretty new to the forum and pen turning. I've made close to 50 pens and pencils so far with varying degrees of success. I use CA finishes often, Pens Plus on the rest.
I've taken to using the Wood Doctors method of sanding thru all the grits of MM using walnut oil as a lubricant. This works well with most woods, but a few, like thuya Burl, stabilized Buckeye Burl, stabilized Box Elder, and one particular board of figured walnut I've been using become very dark as soon as the walnut oil hits the wood.
I have a couple of customers who want brightly colored dyed woods, turquoise box elder and blue buckeye Burl. I turned the pieces and there were bright piles of sawdust everywhere, but when I started sanding with the WO, I got black background with dyed highlights. Beautiful, but not what the customers want.
Any advice about how to keep these dyed woods brightly colored? Lose the WO and dry sand only?? Seal with something before a CA or Pens Plus finish? I have some EEE Ultra Sine on order, thought it might give me good finish after dry sanding to 1500 grit, and maybe seal the end grains and prevent so much darkening from finish, but I think I would have to use the shellac friction polish. Not sure the CA would adhere to the wax left in the wood grain...
I'd appreciate any constructive advice! Thanks!
