CRNicholls
Hi all,
I am looking to purchase a new lathe and of course money is tight so I am going to be looking for a lathe in the $300-400 range.
I have my eye on the Turncrafter Commander 10" and 12" Lathes, but I need to see an image of one from both sides. More specifically, I am trying to determine if the belt access for changing speed is just at the rear (that's the way it appears), or if you have to remove the rear panel AND a panel on the back side to change the belt like you do on the Turncrafter Pro.
The problem is that the lathe must reside up against a wall and I am disabled, so having to move the lathe to access the panel on the back side of the lathe every time I want to change speed is quite a pain. Does anyone here own either the TC Commander 10" or 12" lathe that can tell me if you have to access the end AND the back side of the lathe to change the belt or just the end? Does anyone have pictures of BOTH sides of the lathe? Thank you.
