Help with winter casting
Marines1407
Tennessee
Hello all,
I am having trouble getting my blanks to cure in the cold weather. During the summer my blanks would cure over night. Now they take days to cure. Should I have done a lot of casting over the summer? Are heat lamps an option? I do not have a climate controlled shop and it has been unusually cold here in TN.
Any suggestions on speeding up the process when the temp drops?
I am using Simlar 41 and mostly tube-in casts of carbon fiber. I cast in a silicone mold without a pressure pot.
Thanks.
I am in Tennessee, too. I heat the resin for about 10 secs. In microwave. After pouring, I put them in a plastic storage container that I mounted a bulb holder in. Using a 100 watt bulb, the temp stays about 80 in unheard garage area. I usually leave overnight, but I have taken them out in 2-3 hours. After I take them out of the mold, I leave them in the box to fully degas, so I don't get the smell (using PR)
wow! I use 3 drops per ounce and I measure the resin in graduated mixing cups, heat the resin in the ultrasonic cleaner for one cycle(480 seconds,temp 140-150), put under pressure overnight and they are good to go by the next evening. The ambient temperature will be 30-70degrees
I use four drops per ounce, put the resin/catalyst mix in vaccuum for 8-10 minutes before pouring. After pouring put the filled mold in a toaster overn at 110-115 degree for 45-60 miuntes. Let cool for an hour before demolding. Let cool another hour before turning. Same process winter or summer.
