jimmyz
I need some help!
Made a PR blank (mostly red) with 5 drops per once and let it cure for a couple of days. (No pressure pot, but I did warm the material before doing the pours). Drilled, inserted a tube, and turned the blank to 3/4". Then I remounted it on the lathe and made some "designs" in the blank about 1/8" deep. Did similar designs on a wood blank. Created a second PR batch (mostly goldish) with 5 drops per ounce of PR and poured that into a mold containing the two blanks. Waited a couple of days, cut the blanks apart, trimmed the ends and turned them. Two problems:
1) Some of the second cast material is coming out and creating voids. How do I keep it to stay in? I'm using, I think, sharp tools and light cuts.
2) When I carved the designs in the red PR blank, I noticed some of the material down "in" the design was more light brown vs red. I went ahead and did the second cast anyway because it was a test. Why is the material not red throughout?
Appreciate any help I can get with these casting issues.
