sparhawk
How in the $#*&34$##@%$^%$#@% do you put that keeper clip in the eyepiece. Im sure some of you have found a way to do thids without breaking the glass or throwing the whole thing through the living room wall. Any help appreciated.
Sparhawk,
Put one end into the cutout. Hold that in place with the small finger of one hand, then slide the other end down into the trough with a small screw driver. The middle will fall into place - or you can adjust it with the small screwdriver.
Now wasn't that easy?????!!!!:biggrin::biggrin::biggrin:
You did of course check to make sure that the lens was right side up........
(If not there may be another hole in the wall!!:biggrin::biggrin![]()
That's why I use a small piece of wood. Just happen to think that a bamboo skewer would probably work...... but a little screwdriver will be less likely to scratch the lens...:frown:
