Hendu3270
Hey guys, I was working on my boys gokart this morning and needed to drain and clean the gas tank. In doing so, I broke the small plastic fitting that screws into the bottom of the tank. The other end of this fitting has a nipple that fits into the fuel line and runs into the carb. This is a Harbor Freight 6.5hp engine and I'm not messing with ordering a part through HF. From what I've heard it take forever. The more I look at this fitting, I'm pretty sure I can create one on the lathe. My question is what material should I use to make this part? Something that won't be affected by gasoline and that I can obtain a rod that is 3/4" diameter. Thoughts??
