Unfortunately not. When you cast, its pressure you use to compress air by pumping it in to a pressure tank with an air compressor. When you stabilize you pull air out with a vacuum pump to force the resin in while bringing back to equal pressure. Also, Casting resins don't penetrate like stabilizing resins because of the way they are cured.
