Grizzly G0765 7" x 14" Variable-Speed Benchtop Mini Lathe AND Accessories ( CHICAGO - EXCELLENT CONDITION )
slubs
Chicago
Hey everyone. While I'm sad to see it go, selling my entire mini lathe setup. I'm located in the Chicagoland area ( northwest suburbs ), so hoping to find someone in the area. Would also consider delivering it, if you're close or located in the city.
Asking Price: $1,800 ( *happy to hear offers though, just message me )
REDUCED Asking Price: $1,600 ( *happy to hear offers though, just message me! )
This includes EVERYTHING you need to get up and running with the lathe for any hobbies or light professional work: 4 jaw chuck, 3 jaw chuck, an ER-32 collet chuck with a set of 2 mm – 20 mm precision collets, and most importantly, an upgraded quick change tool post to make using the lathe much more user friendly and enjoyable.
*Please see the pictures for a full view of everything included. I've included the product description from Grizzly as well as a short list of just some of the accessories that are included. Everything is in excellent condition with very little use.
CONDITION:
The lathe is in excellent condition as I didn't get as much use out of it as I would have liked, and when I did use it, cleaned it meticulously after each project. As you'll see in the pictures, I have cleaned the lathe to get it ready for its next user as well, including taking off the panels to make sure the gears are clean and in great condition.
WEBSITE DESCRIPTION:
If you're in the market for a benchtop lathe that doesn't skimp on rigidity, then you'll love our G0765!
It features a special "Big Boy" tailstock which was designed with the same convenient quick-locking controls and extra-long footprint previously only found on our much larger lathes.
It also features a variable-speed spindle with digital RPM display for dialing in the perfect cutting speed, a two-speed gearbox for the extra torque needed when turning at lower speeds and the ability to cut a wide range of inch and metric threads.
This lathe includes everything you'll need to get up and running, including a 3-jaw chuck with internal and external jaws, 5" faceplate, steady rest, 4-way turret tool post and MT#2 and MT#3 dead centers.
Like all Grizzly lathes, the G0765 comes with a 1-year warranty covering parts and assuring the unit is free from factory defects. (Consumables are not covered by the warranty.)
The G0765 manual was written by our U.S. based Documentation Department is packed with useful information.
The Grizzly Technical Support team is U.S. based. Parts and accessories are available online and shipped from the Grizzly parts warehouse in Springfield, MO.
Made in an ISO 9001 factory
SPECIFICATIONS:
  • Motor: 3/4 HP, 110V, single-phase 10A
  • Swing over bed: 7"
  • Swing over cross slide: 2-1/8"
  • Swing over saddle: 5"
  • Distance between centers: 13-3/4"
  • Bed width: 3-1/4"
  • Spindle bore: 0.78"
  • Spindle type: Intrinsic back plate
  • Spindle taper: MT#3
  • Tailstock taper: MT#2
  • Tailstock quill travel: 2"
  • Cross slide travel: 2-3/4"
  • Compound travel: 2-3/4"
  • Spindle speeds: Variable, 100–2000 RPM
  • Longitudinal feeds: (1) 0.004 in./rev.
  • Inch thread range: (18) 12–52 TPI
  • Metric thread range: (10) 0.4–2.0mm
  • Footprint: 8-1/2" x 29-3/4"
  • Overall dimensions: 30" W x 9" D x 10" H
  • Approximate shipping weight: 110 lbs.
FEATURES:
  • Variable-speed spindle with high/low range and digital readout
  • 16-TPI reversible leadscrew
  • Cuts RH and LH threads
  • Chip tray and backsplash guard
  • Emergency stop button
  • Forward & reverse in all speeds
  • Inch/metric dials
  • Threading dial indicator
  • Quick-locking tailstock
INCLUDES:
  • 3" 3-Jaw chuck with internal & external jaws
  • 5" Faceplate
  • Steady rest
  • 4-Way turret tool post
  • Complete set of change gears
  • MT#2 & MT#3 dead centers
  • Service wrenches
  • Bottle for oil
  • Extra fuse
ADDITIONAL ACCESSORIES BOUGHT BY ME FOR THE LATHE:
  • Upgraded Quick Change Tool Post Set ( MSRP: $200 )
  • Lathe Protective Cover ( MSRP: ~ $20 )
  • Collet Chuck, ER-32, 4" Diameter ( MSRP: ~ $130 )
  • Collet Set, ER-32, Precision Set of 20 Metric, 2 mm – 20 mm ( MSRP: ~100 )
  • Diamond Tool Holder
  • 1/2" drill chuck, 2MT standard to 33JT drill chuck arbor
  • Oil for treating the machine after use
  • …and everything else pictured!
