RogerGarrett
I have an older, 14 inch Delta drill press - model 14-070 that has a crack in the 90 degree angle bracket that holds the table in place. The Cast iron bracket is welded to the table - it is all one piece. I can remove the table - leaving the raising and lowering mechanism in place, and I had the table brazed/welded once - but it is cracking again.
Apparently, this table is a part that is no longer made and I have no way to really use the drill (which is just fine) without a good table.
Any suggestions as to how to replace the table with another (Delta tells me there is no replacement available) or to still maybe fix this table?
I'm not opposed to just buying a new drill press (love a new tool purchase!), but it seems like a big waste of drill press power to toss this one?
Best,
Roger Garrett
Best,
Roger Garrett
