Conversion Pump usage question
LouisQC
Gatineau, QC, Canada.
A newbie question...
Is the pump supposed to be refilled by dipping the nib into the ink or is one supposed to remove the conversion pump and dip it's collar into the ink? Basically, do you remove the pump from the nib section?
Yes either way would work but I leave the nib attached also, just be sure that the nib is below the feed hole and that when it's full release 3 drops out.
