juteck
It's most likely an obvious answer, but after soaking coffee beans in a thin plexitone mix to stabilize, take the beans out and let them drain, then spread out to dry. What material do you spread them out on to dry that will allow excess material to drain away from the bean, but not cure back onto the bean. Paper towel drains them, but sticks to the beans when drying. Wax paper doesn't stick, but doesn't allow the excess to drain away completely, leaving some beans with lumps. So, how do you dry them?
