The easy cast epoxy as been stated has to be mixed in exact portions.
from their web site
Soft & Sticky Castings:
Is a result of improper mixing or inaccurate measurements of resin and hardener. These soft or sticky castings will unfortunately have to be disposed of. Prevention: Do not guess at the proper ratio or just empty the two bottles into your mixing container. Use a proper measuring device and measure equal portions of resin and hardener. Always double mix as per the instructions. Note: Inadequate measuring and mixing is the most common reason for imperfect results.
Consumer Products | Environmental Technology Inc
They have a page about the product and instructions. Heat will not help chalk it up to a learning curve.
The do have and sell a PR clear casting resin.
Since you have a hobby lobby here is their site for the 40% off coupon
In-Store Coupon : Weekly In-Store Specials : Hobby Lobby - Hobby Lobby
You will cut down on problems if you use only approved dyes and colorants, along with the pearls and mica's and other materials. Water based powder paints and acrylics don't work well with the resins.
:clown:
