Casting - Help ?
Gordon
Wichita, KS, USA.
I've been PR casting Avery labels on brass tubes that have been powder coated gloss white without any problem. (30 psi - PR - 6 drops per oz -
cork sealed, for 5 hours).
However when I attempt to cast without the Avery labels directly to the powder coated tubes - the cured color of the tubes is only partially white and has a silver-like color at the tube ends.
Sorry I don't have the ability to provide a picture - but hoping someone
can advise.
Thanks as always.
Gordon:confused:
Because the powder coating process is based on heat to melt the particulates the problem is most likely the heat generated through the chemical reaction of the PR. Answer: Cast a regular blank then drill it and glue the PC tube in place.
Good Luck!
Hey Gordon, I don't understand what you are saying
...without the Avery labels...
...cured color of the tubes...
I can almost guarantee the silver-like color on the ends of the tubes is some how trapped air...
Air bubbles seem to stick to certain materials more than others. I have no problems with labels either and I paint the tubes with white primer, but other embedded material will cause problems much like you are seeing.
Do a good turn daily!
Don
Gordon:confused:
The resin is separating from the tube. You are seeing the air gap.
Does it look similar to this, only on the ends?
I think allot of these problems are related to shrinkage. As the PR cures it shrinks and pulls away from the tubes . For clear casting Alumilite is better in some ways , it don't shrink .
The picture I posted IS Alumilite. I have never successfully cast a label or tube using Alumilite. They all separated like the one in the picture.
That is a problem with alumilite. That's why I continue to use PR for doing snake skins....it is much better for this application. Change to PR and your labels with come out really nice...and it's cheaper. Your turn Curtis. :)
Don
Don
I now only use PR. That picture is from when I was testing both products to make an informed decision.
