Alumilite water vs Alumilite clear?
hanau
thomasville, nc, USA.
i order the water clear reading thru the "Differences in Alumilite forumlations"
Curtis says the water doesn't polish as nice as the clear.
How much difference really is it?
The bottle i have purchased I still will use since I will have to go thru the trail and error.
but just wandering the difference in the polish.
It can be significant. Also, Water Clear is a much softer cured resin. If you are using it for Worthless Wood casting, then the polishability is not an issue since you should be using a CA finish on it anyway.
