turn between centers
  1. P
    Turn Between Centers
    A cheer here...well, actually 3 cheers to Brian at Turn Between Centers, for customer service that is second to none!!! As some/many/most of you may well already know, Turn Between Centers sells precision bushings for turning your pens to delightful concentricity. Brian's customer service...
  2. jrista
    Protecting Dead and Live centers when doing TBC?
    Well, I started doing TBC in the fall last year. It solved numerous problems I had been having with mandrel turning, and has allowed me to get pretty much perfect seams between the blank and the kit parts. However, it seems that even with TBC bushings, I am having problems with both the dead and...
  3. jrista
    Still getting out-of-round with PSI Turn-Between-Centers Mandrel - Need some help
    I've been turning pens...well, for almost a year, although there have been some largish gaps. The last couple of months I've really gotten into turning pens more, after watching some of the presentations at a pen turners virtual conference in May. Learned a LOT from that conference (sadly, all...
  4. theHullTurn
    Turn between center bushings and respirator recommendations?
    Hi all, want to get into turning between centers. I have the necessary hardware minus bushings for this. Any vendors that you guys would recommend? Also, doing more with CA finishes and just turning in general I am wanting to get a decent respirator. Any good solutions that you guys have...
