too dark
  1. M
    Need advice for special project finish
    I'm pretty new to the forum and pen turning. I've made close to 50 pens and pencils so far with varying degrees of success. I use CA finishes often, Pens Plus on the rest. I've taken to using the Wood Doctors method of sanding thru all the grits of MM using walnut oil as a lubricant. This...
