stanhope lens
  1. P
    Stanhope Peephole installation in Pens - Tube and Hole Method - Tutorial with photos
    Installing a stanhope in a pen that has a 3mm inside diameter tube somewhere through it or on it, is as simple as gluing a rod inside a tube. Photo1: Getting started (items needed) Installation Tips - Before You Start -The most important point to consider when installing a stanhope lens...
