slow speed
  1. Fine Engineer
    A Technical Question Regarding Variable Speed Drives
    So I have a WEN 3421 lathe with the variable speed drive. Does anybody know if I could use a variable voltage power supply to get lower speeds? My thought is that for doing some fills with epoxy, you need to keep it rotating slowly so that the epoxy doesn't sag while it cures. The slowest speed...
